I need more. It's not loud enough.
get an 80 prs instead and future proof yourself. That alpine is still half @ssed in the tuning department.
I agree
Not a jab at all, curiousity. Can't really expect Zapco to produce something at that price range that represents their older much higher quality designs.
I've been watching the Zapco ST-4 for a while and this:
https://www.mmatsproaudio.com/site/product/ls800x4/
In case I ever want to buy a few to upgrade. The LS800x4 is especially a good deal I just wish they'd list RMS instead of peak. I even emailed them about it and the owner got back to me stating it was for marketing because it's a budget product
Rms is 90x4 at 2ohms.  It's in the downloadable manual.  No 4 ohm rating tho
The mmats?  Yeah, dont bother.  That 900.4 makes insane power.  If you can f ind a deal on a ppi bk520.4, those are powerful and sound amazing being class ab.  The ppi bk800.4 would shred too
Yeah, not in the market for another highs amp. Now, a Sundown 1500 or suitable equivalent, I need. I've got enough highs amps laying around than I know what to do with. At least six, including the one in my truck, ranging from the diminutive  Eclipse EA1412 to the monsterous P900.4
Just saw the zapco is 640 watts.  If thats rms and you want more volume, listen to jeff.  Seems like there'a setup issue or your eardrum are giving up the ghost.  I had a 900.4 on 4x infinity reference 6.5s, couldnt really say it wasnt loud enough.   If it's not setup related, time for a revamp.  Or hearing aid.
What can I say, I like my music loud. I did quite well on my hearing exam when I had my physical for work a year ago, for what it's worth. I'm mostly having issues with certain types of sounds coming through well. Instrumental tracks and EDM seem to be pretty safe, aside from tracks that make heavy use of square wave synths (damn you, chiptunes) and the occasional sawtooth. However, tracks that have alto to tenor vocals (low female, high male) tend to distort in that vocal range prematurely. So I'm almost certain that I need to reset my EQ so as not to overdrive those frequencies, and look into components that can more efficiently reproduce that range. Soprano ranges come through just fine. So I'd imagine in the range of 400-1000hz is where my setup is lacking efficiency.
It's not a matter of power, if I were to  grab the MMats I'd be grabbing 4 of them and bridging them all. Guarantee it'd sound better than 2 ppi 900.4's
Alright, alright, amp discussions aside, are there any component recommendations under $300 that would be an improvement in the sub 2000hz range over the JBL P660C set that's in my doors?
Hey mate, if you are after more volume in your ride then go audition a few components with high sensitivity so they will be more efficient and will get loud without you turning up the knob too high.  I would recommend JL Audio or Kicker even Pioneer are better contenders. It also depends on what brands your local car audio shop has.  You can go Focals but I have found the European brands tend to have a flatter sound for my liking. Hertz components are another contender so is Audison and Morel speakers.   Best to go listen to some and then you can haggle the salesperson to give you a good deal.
Later mate!
Later mate!
Might look into some Hertz or Morel. I don't suppose Cadence is worth looking at? JL is good, but can't justify their cost. Unfortunately there's no audio shops in my vicinity that have actually decent components on their boards and cater mostly to the low tier crowd with crap like Planet Audio, Crunch, Boss.
For what it's worth, my current front stage has a 94dB sensitivity, which I find suspect, since most components in the 100w rms range tend to be between 89-91dB.
the first thing you want to do is say fk off to the components idea and get rid of the kenwood head unit.    You want to use raw drivers with no passive crossovers, all crossovers are done on the 80 prs head unit.    The signal will be split into high, mid and low which means tweeters, midbass and subwoofer.
some loud cheap tweeters,   https://www.amazon.com/Massive-Audio-CT2II-Tweeter-Crossovers/dp/B00NBC25UM
some decent mids https://store.soundsolutionsaudio.com/products/crescendo-un-65-6-5-pro-audio-speaker.html
You'll need to use your ppi 900.4 and your current zapco for this because those UNs love power, they just sound better and better with more power. you will either bridge the ppi or the zapco to 2 channel stereo to the crescendo UNS yes they will eat up all the power and more without issues, just raise the HPF depending on how loud you want it. Now with the remaining amp, you'll want to power the tweeter and the rear speakers.   Your midrange RCA on the head unit RCAs will be split with an rca splitter to get signal to the rear.  I'd generally recommend losing the rear speakers completely or leave them on head unit power but i understand its a big car and passengers might want something back there.
Start off with the head unit in network mode and try a 4000 hz at 12 db crossover point for both mid low pass and tweeter high pass and tune around.
your tweeter is 94 db, not the midrange, the midrange on the p660c is more around 89 db sensitivity.   If you like the tweeters, you can follow the blueprint i listed up there, but dont buy the tweeters, just use the p660C tweeters and get rid of the passive crossover and mid and replace it with the UN6.5 and run everything active.
318
320
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
336
phantom240
ALL YOUR INTERNETZ
phantom240
Southeast Louisiana
phantom240
    May 24, 2024
    May 23, 2024
