why doesn't my subwoofers sound louder?
Please reword your question if you haven't received a proper answer.
My question was, why is my sub so LOWWW. Volume wise. lol
I had the PAC line out convertor and was told thats why it was low volume ands needed the better active LOC. Fine., And now everything has to be turned up all the way except the amp gain....its at like 70%-75%. Maybe its just cos I have and 8" idk
Did you resolve this issue?
Hate to come back at ya bro but you may need to do some reading. lol Im adding a sub to my stock stereo adn theirs limitations to how much power you want.
Gotta take into consideration the wattage of the rest of your system.
Many stock systems would require a sub no more than 200W RMS.
Im running a 1200 watt amp at 4 ohms, 500 RMS and a Skar SVR 8" at 400 RMS with the LC2i 2 Pro LOC.
What you may be able to help me with...is running it at 4 ohms a good bit lower output than 2 ohms?
If so, I could just buy another 8" and run them at 2 ohms...
What the f*ck kinda **** are you smoking?
Yeah its resistance. and its funny cos everyone runs their sht at 1 ohms it seems and its the worst way to run an amp and doesnt sound as good as 2 or 4 etc.
And Im sorry I wasnt clear. Youre supposed to take the watts of the other speakers and having a 50/50 or 60/4060 being sub power.
And amp INPUT is hard to get info on and its important. Cos the LOCs put out 2V or 8V and that effed me up at first.
Man get the f*ck outta here. I don't know where you get any of your info but you be saying some dumb@ss ****.
Yep. See, it's just unwise to f*ck a horse. They will seriously f*ck you up with one kick. The thing with f*cking cows is that it's not bad but they will **** all over you almost everytime. Goats on the other had just sit there and take the d*ck.
Asses take the dick. I mean donkeys...
This type of controller will work on any amplifier (or specific channel) as it is inline with the RCA connections and functions entirely as volume...
977
Mixed Mono has also been around for many years from the 80s as well. Ill use a set of 4 ohm components with a passive Xover and throw in a 4 ohm...
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
Sounds like an issue with the programming in your head unit. The designers didn't anticipate the day where the head unit would need to read 700...
MROOD
MROOD
London
DRBOOM
