TIME TO START BUILDING!!
KicktheSDbasshead
2 builds 2 feet
I seen you're pretty familiar with the taramps line I mounted those fans in the pict on the bottom of the 15k do you see any problems with doing that?
I am pretty sure that that type of FAN needs to be installed vertically to get some fresh air movement /Flow through to get some real CFMs out of those fans. Laying Flat on a flat surface, no air being flowed through the fan and heat will eventually kill the fans out one by one and may not keep up with keeping your amps running cooler. It would be best to cut out the backside of the wood for the fans and or as well as place 4-5 washers to get some room under the fans bolt down/feet to get some Flow and fresh air moving. Or... Trash those and look into some high cfm Scroll fans. I use Stinger 6" and 8" scroll fans. Those mount on a flat surface and would work very well. But as you have those installed. I would recommend taking one fan off and using a hole saw and drill out a min. of a 2-2.50" hole for each fan to get some air flow and fresh air movement and get some heat out of that location a bit better.
The amps will be raised to get airflow to them also there are holes to push the air Into the amp
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
997
Not with a Toyota but with a Dodge Stratus. The Security Key Immobilizer Module (SKIM) was activated and it would not energize the coils. Check if...
That's what I'm going to do, cheap, and easy to do. I picked up a spst switch today
I found a solution that you may try. PAC TR-4 Remote Turn on module. It's on Amazon for about $17.00
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
KicktheSDbasshead
2 builds 2 feet
KicktheSDbasshead
San Diego
KicktheSDbasshead
    May 19, 2024
    May 19, 2024
