Need help with sub box design
If this is going in the trunk then it's gonna be huge, I mean depending on tuning, but damn that's 6kw and 5-5.5 cubes net internal needed. I'd be thinking more along the lines of a wall or series 6th wall vs an aero port. If those are decent subs, then I mean that box probably needs to be massive to be like max efficiency of the woofers working. Tuning will make a big difference in box size with a large port, like you're probably looking at a box size externally of like 7 cubes or more to maximize those, just roughly speaking. You can somewhat get away with less port area in trunks firing rear or not forwards, but IMO not really with 6000w, like I just don't see that working well unless you have a very large aero and tune it to like 40 hz to keep the box small and the port length small enough, but that's gonna be peaky as hell and unload somewhat quickly, drop off on lows. You also can make the box too tall or wide or deep where 6kw worth of air pressure is having to barely squeeze its way in between the trunk walls and the box walls, gotta be careful there. And with firing forward and not sealing, you can run into cancellation issues with the trunk walls and box walls depth and airspace (airspace around the box inside of the trunk) acting like a t-line or a secondary ported box and phasing out certain frequencies. That can be a very big issue.
With that much power, you probably should work with somebody with a box design. I can't do it, but you wouldn't wanna waste that significant of a system, just a thought.
Big coils and high FS, like I’ve mentioned in the other thread, big box, power hungry, and the low end output won’t ever be anything amazing. The sound of subs like this aren’t my cup of tea either. If you like most of the output above 40-45hz then you may love it.
There are always compromises when dealing with the end goal of very high input/output. It modeled pretty good from about 33+
A single 6" aero is not gonna do these justice IMO.
Yeah, I'd have to go back in and see what the vent velocity looked like. A slot might be much better but then we're talking about a bigger box still, which, it appears would work too. Originally looked at the least obtrusive options prior to getting the largest box that the OP would consider. Those 12's are beasts!
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
This thread is over a month old. Shame I missed it, the whole thing is shameful and hopefully OP made those people give him an install that...
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
Old_Slapper
    May 10, 2024
3toneEYZ
    May 10, 2024
