Kenwood DMX47S AppleCar Play - Loud Text Alert
  • 2
Tammy Herzog
I have the Kenwood DMX47S installed in my 2015 Highlander and am at a loss as to how to turn down the volume for the alert for a text message when I am connected to Apple Car play. I have tried turning down the volume on the phone prior to plugging it in as well as adjusting it while it is plugged in and still get an extremely loud notification at times. Other times the notification alert is tolerable. Any help wold be appreciated.
Try going into your settings and look for system sounds. You may be able to adjust it there.
Or, you can go into your phone settings, look for Apps, select you text app and turn off the notification for text.
Good Luck.
Some don't have that option. But it does have an internal amplifier otherwise it wouldn't put out the 21x4 it claims to. Check the eq settings...
13
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
413
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
714
Tammy Herzog
Tammy Herzog
Oklahoma
huberoy123
    May 19, 2024
    May 18, 2024
