Need some advice with wiring
supafly1
Hi all, I have an android head unit and a puzu pz-c7 dsp amp, when installing my subwoofer is it better to have the sub amp connected to the head unit sub output or the puzu dsp sub output,
may be a stupid question but I'm clueless when it comes to sound.
Thanks a mill
Yup , the dsp should have input sections, it may have one for sub?
Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all out, and think for the whole signal flow, and why it’s like that.
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
472
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
822
Try removing all the signal from the amp, turn the gains up and down, see it is present. If it is, then the amp is the issue,if not, then it is...
supafly1
supafly1
South Africa
chipss36
    May 18, 2024
    May 16, 2024
