Speaker impedence and performance
  • 2
kanihoncho
I've installed four head units (HU) with speakers in my life and one complete system with HU, amp, wiring, and crossovers with never an issue. I can do the work if the instructions are clear. I'm no genius when it comes to all the issues matching components and installing them.
Question: If a speaker is rated at 3Ω and an amp is rated at 50W RMS per channel at 4Ω, will the 3Ω speaker have slightly more performance in terms of output . . . say 60-65W?
The amp will need to be stable at 3 ohms or you will burn up the amp. If the amp is 2 ohm stable then you will see about a 16.5% increase at 3 ohms over 4.
How do I know if an amp is STABLE at 2Ω? If it's rated in the spec? These are the specs for that amp. In my ignorance I thought I would need to have 2Ω speakers to get 75W output. Would these speakers be somewhere between 50 and 75W because of their 3Ω rating? I do understand that power is logarithmic, so a 3Ω speaker would not quite get close to 75W, is this correct? I guess I'm a little confused as to what a speaker draws and what an amp puts out.
5-channel car amplifier specs
  • 50 watts RMS x 4 + 300 watts x 1 at 4 ohms
  • 75 watts RMS x 4 + 500 watts RMS x 1 at 2 ohms
  • 150 watts RMS x 2 bridged at 4 ohms + 500 watts RMS x 1 at 2 ohms
Your 5 channel amp is 2 ohm stable on the primary 4 channels at 2 ohms if it lists that capability/spec, which it does. I assume you are running the 2 front L/R and 2 rear L/R and they are 3 ohms each. At three ohms, that amp would provide about 62.5 watts of power x 4 to the 3 ohm drivers. You'll not likely hear any difference between 62.5 and 75 watts. It's less than 1 db.
That is correct. Thanks for making that clear. One last question . . .How does the amp know whether the speakers are 2, 3, or 4? Is it a setting or is it just a function of physics?
446
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
427
573
484
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
kanihoncho
kanihoncho
South Carolina
kanihoncho
maylar
    Jun 2, 2024
    Jun 1, 2024
