on the manual it says:
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 200 Hz)
Mono into 4 ohms ................................................................................................................. 100W (0.08% THD)
Mono into 2 ohms ................................................................................................................... 150W (0.3% THD)
Power Output: RMS Continuous Power (at 14.4V, 20 Hz to 200 Hz)
Mono into 4 ohms ................................................................................................................. 150W (0.08% THD)
Mono into 2 ohms ................................................................................................................... 200W (0.3% THD)
now further in the manual where there are diagrams and such it does not specify on how to wire for these different loads, i am pushing 2 kicker comps off this.
are amps "smart" in thesense they use the best option per sub they are connected to or is it a wiring issue to get different output?
how would i wire my subs (they are 150 rms @ 4ohm) at the 150 rms @ 2 ohms?
im confused
im confused
