Has anyone used these in a car? (Emotiva Big Ego)
  • 6
+1
I saw this mentioned somewhere else... https://emotiva.com/collections/personal-audio/products/big-ego
Was thinking of having one mounted behind the dash to get a digital signal from TIDAL over USB converted to optical toslink to go to my JL Vxi Amp
Would bypass stock HU.  already have a volume knob on the amp so that wouldn't be an issue
sorry for the spam new dood, there are a couple "people" on this forum that always say "+1" or something gay like that and the admins wont ban them. tomhang is one of the others that do this. we suspect they are the same person with different login ID's or bots. Anyways, youre not likely going to find anyone on here that uses a D/A converter instead of a headunit. too many potential pitfalls
What are the pitfalls?
Here are potential advantages
  1. Digital signal directly to DSP
  2. Maintain all factory esthetics, controls, integrations
  3. Low cost
  4. Convenience of phone app like TIDAL, no additional hardware to download music files to
+1
it should technically be a much cleaner signal than a normal head unit since the DAC is a much higher grade.
yeah, i missed his second post showing the dsp he was looking at and only realized it after he said that he was confused because he was going to go directly into it from the interface
also, +1
find attached pics of my amps and the speakers/sub in my trunk
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
I use these and they work great. I splice them right before the LOC. One leg on the negative the other on the positive.
Justin Garrett
Justin Garrett
youdoofus
    May 18, 2024
    May 16, 2024
