C-LocJiggleNuts
Looking to bang but have limited space. 2015 Dodge Ram Crew Cab. Wanting to run 2 12’s off a Rockford T1500-1. Ready, go.
so what are the mounting restrictions? Are you thinking underseat?Not too concerned about the budget. It’s more what would work best in the space. I’ll have about 1.5 cu3 each side. I listen to everything so want to be flexible with adjustment from country to spl tracks.
Gotcha. The box i want is vented and tuned to 35hz with 2 12’s and after digging deeper looks like the Sundown Sa12 would be right in the ballpark of cu3 needed to be in spec. The T1 I currently have is good for a stand alone sub but needs too much space to run duals.Low end performance has more to do with the box design rather than the subs. Tune the box low and build it strong and it will play low no problem.
Sounds like you are looking at a prefab box. Those are pretty awful at best. 35hz is too high of a tune if you want good lows. You need to either build a box yourself or pay a shop to build you a custom box.Gotcha. The box i want is vented and tuned to 35hz with 2 12’s and after digging deeper looks like the Sundown Sa12 would be right in the ballpark of cu3 needed to be in spec. The T1 I currently have is good for a stand alone sub but needs too much space to run duals.
You thinking about stuffing a pair of Sa-12's in one of these?FoxBox
Shredder, not a good idea? Thoughts?You thinking about stuffing a pair of Sa-12's in one of these?
http://www.foxacoustics.com/ProductDetails.asp?ProductCode=DQC-212-V
On a T 1500-1?.. oh boy...
