Odd head unit action-title scrolls one time, stops
  • 2
Mike Reese
I have a 'Ebay' special Chinese made head unit in my old car (a '01 Accord, desperation buy) with touchscreen, bluetooth, etc... well, since I've had it. it works well enough for my purposes, and I like the mp3 tags showing on screen, but long song titles and such don't show in full. Not a problem. BUT. Just yesterday I put new music on the USB drive I have for it, and on ONE album, and just that one, the titles started to scroll!! The next album? No. I took the USB drive and looked at the files in my PC. Nothing different from the first time I put them on there. So I put the drive back...and the titles on that album DID NOT scroll this time. I'm not losing sleep over it, but do any of you have an idea of what happened here?
does that one album have ID3 tags and the others not? Plug it into a computer and go into the details of the titles that scroll and compare them to the ones that done. Look for the ID3 tag section
Thanks for replying...yes, that album, well, all of them have ID3 tags. All of them. I'm now thinking it's some fluke with the unit. I went through the tags again, checked them with my MP3 editor, again, and some that previously showed proper album art didn't, even though I didn't change them in that last check. I'm still wondering, though..
can you try it on a different deck?
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
i see, good to know At least. that means i could squeeze out more air volume indeed. bit of a crude design but so far was thinking of roughly...
It sounds like the remote is wired to the interior courtesy lights. Those lights come on as soon as you remove the key from the ignition. Try...
387
Mike Reese
Mike Reese
Mike Reese
just call me KeV
just call me KeV
