X-over and input volt questions
  • 2
KoG
I have 2018 Camaro SS 1LE non-Bose, no factory amp.
Here's my setup: I am planning to use the PAC AP4-GM61 module to get the RCA clean-signal output straight from the 8" factory HU. It will then hooked on to the Rockford Fosgate P1000X5 amp via the RCA.
The output to the speakers will be:
FRONT: RF P165-SI components with x-over built into the basket of the woofers/tweeters.
1) Now here's my question, on the amp it has LP - AP - HP. Do I set it to AP since the x-over are built in the speakers? or should I still set it HP?
REAR side panels: RF P1650 Coaxial 2-Way
2) This would be set it to AP also?
SUB: I haven't fully decide on which sub I want but it will be a ported enclosure. Obviously this channel will be set to LP.
3) On the amplifier, there are knobs for FRONT and REAR input level: 12.0V to 0.15V. How do I know where to set this at?
EDIT: The manual for the PAC-GM61 states, “AP4-GM61 delivers variable 5v RMS pre-amp outputs with fading.” I would set it at 5V. I believe there’s a 4V on the dipswitch too.
Correct me if I'm wrong but doesn't that amp have their clean set up. Just follow their directions that'll get you close then you can fine tune by ear. Since you're using a sub I'd use hp on the mid and coaxial unless you want them playing low bass that your sub is playing
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
554
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
837
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
The ZVX 8 doesn’t do well sealed. 1.25 cubes ported 35-38 HZ is what it will like. Very inefficient 8 and wasn’t very impressive to me, even in a...
KoG
KoG
fithwheel
