Has anyone bypassed the Bose factory crossover?
  • 2
I have a 2015 Silverado with the factory Bose system. I tapped into the factory sub speaker wiring to send signal to an amp for a 12” sub upgrade.
The problem is the signal is processed for the Bose sub. The crossover freq and eq settings a garbage.
I’ve tried tapping into the signal everywhere, amp in, amp out, other channels...all have the same crossover issues. At this point my assumption is the signal comes from the factory “head unit” processed.
Has anyone successfully bypassed this processed signal? Or even found a way to edit the factory presets?
thanks for the help!
sorry to say, but i think you are right and that, of course, means youre screwed bro :(
find attached pics of my amps and the speakers/sub in my trunk
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
I use these and they work great. I splice them right before the LOC. One leg on the negative the other on the positive.
tank313
tank313
Los Angeles, CA
youdoofus
    May 19, 2024
    May 19, 2024
