F150 Sony sub install
So I have done a lot of research about this and I know that some people might say just search for it but every post I've looked at gives me a different answer. I have a 2013 f150 lariat with the Sony system and I want to add a different sub. Some body said I could just buy a line out converter (I was looking at the LC2I) and then just connect it to my speaker wires. Is it really that easy? Another forum I read said that there was a lot of other stuff you had to do, so I just want a definitive answer before I buy all of this stuff. Also what is the best sub and amp setup for this truck that is not crazy expensive?
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
Thanks so much guys. Talked to crutchfield support with the same question and although they likely don't know everything, and sometimes, salesmen...
They really are. Fit to perfection! Sounds Good Stereo are the best.
Tcrosby2011
Junior Member
Tcrosby2011
Thomasville GA
Tcrosby2011
    May 18, 2024
    May 16, 2024
