- Thread Starter
- #16
I appreciate the info. Looking at something like the Machete M12 v2 D1/D2 Sport 12", specs say it likes 950w RMS. Will my current amp sufficiently power this bad boy?I would look closest at the FU and the Machete. If you can buy a step or two higher in the alphard brand do it! (Sports or super sports)
big 3 at your power level is not necessary, you’re not (probably) going to crash and burn by not doing it. But you REALLY should especially to future proof it’s really easy. They will make you a kit at gpcaraudio.com with all the ring terminals pre crimped do all you have to do is bolt it on. I would do the 2/0 OFC just so you never have to worrry about it if you upgrade. My car is almost 100% 2/0 ofc and i would have done that regardless if I was running 300 watts or 30,000
Best batteries in the business are northstar. Would be worth your while to invest in one if you go any bigger.
Should I worry about going with a 1ohm or 4ohm DVC sub? Need to wire it for now at 2ohm, but also thinking about what makes most sense if I decide I want another sub. I guess you can always buy an amp for whatever I decide to go with.
