Fuse size
  • 5
brokeboi77
What size fuse for alt to battery?
360 amp alt at 1800 rpm (can hit 375 amps)
Wire rated at 375 at 20ft. Probably could handle 400 amp at its current length.
i would need a 375 amp fuse or would it blow from the alternator exceeding that?
You dont fuse for potential power, you fuse for DRAWN amperage. If you only draw 100 amps, you need a fuse slightly bigger.
A 375A fuse will pass 375A basically forever, 400A a long time, 500 probably several minutes.  You get the idea.
Better to under fuse a little than over fuse even a little bit.
So youre saying that a higher amp fuse will blow faster? How idiotic is that?
Good work.  Lob undeserved personal insults due to your poor reading comprehension skills.
:thumbupw:
The statement being idiotic doesnt mean you are. Talk about comprehension... You still need to clarify your assertion that a higher amperage fuse wouldnt hold as long.
You're the only one who seems confused.
For the intellectually impaired...
A 375A fuse will pass 375A basically forever.
That same fuse (as no reference to any other fuse was made) will pass 400A for a long time.
That SAME fuse (again, was any other fuse mentioned?) will pass 500A for several minutes.
Unless you're a dum dum boy you get the idea.
Got it now, little buddy??
:thumbupw:
Jeez.
oh and btw amplifier to battery fuses are fused for the amplifier or wire?
cause more than 300 amps per run into my amplifier doesn’t sound good to me. (13k rms - 4 runs)
Fuse protection is always for the wire.
Generally, if there's enough of a current surge to blow the fuse in the wire -- the component that caused it is already toast.
The point of the fuse is to avoid a car fire if the wire gets damaged and touches the chassis ground.
I only used one comma.  Hopefully antique rice driver can understand.
Fuse anything going to the battery 150amp fuse I would do. if it shorts you saved your battery, and than you look for causes why it happen, if...
Same here. Its what my search pulls up, but its all over the place
952
I made a lot of money repairing fuse boxes that were destroyed from people taping into them. Pay once by doing it right. Do it wrong, the second...
14
484
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
643
brokeboi77
brokeboi77
Juice Man
    May 31, 2024
    May 24, 2024
