6 Dual 2's on a bass 8k wiring help
  • 5
MattinMO
Say if one had 6 dual 2 ohm subwoofers and a taramps bass 8k 1 ohm, what is the optimal wiring diagram? I don't know why I cant wrap my head around this so flame me all you want.
so 2 banks of 3 subs wired 1.3 ohms each bank final load be 2.6
3 banks of 2 subs 1 ohm each bank but then the final load be 3 ohms
….im retarded lately...teething baby = no sleep
You can wire to .66 but I'm not sure what the bass 8k is stable to. If you're talking about a hd8k you shouldn't wire it below 1 ohm
Six DVC drivers with Voice Coils in Series / Parallel
Six Dual Voice Coil Speakers in Series / Parallel
Connecting the two voice coils of each driver in series (+ to -) and the drivers themselves in parallel (+ to +, etc.) will result in the following impedances:
  • Dual–8 Ohm Subwoofers: 2.67 Ohms
  • Dual-6 Ohm Subwoofers: 2 Ohms
  • Dual–4 Ohm Subwoofers: 1.3 Ohms
  • Dual–2 Ohm Subwoofers: 0.7 Ohm
  • Dual–1.5 Ohm Subwoofer: 0.5 Ohm
No reason you can't get the sound you want with ported or passive radiator but if you have no ability to tune the mass of the passives you will...
188
507
MattinMO
MattinMO
St.louis, MO
