Help Identify...Earthquake of San Fransico amp, cant find info..
AbraKaDaBrah
Last resort. Hi guys 🖐. I have spent alot of time over the past year looking for info on my amp. I bought from nephew in 2003. He said it had been sent back to Earthquake of San Francisco and upgraded for $185. Still works, need to sell. Help identify? Thanks in advance!
Earthquake PHD Mono Block, Built in 1999 these specs are close, might be 100% accurate
1000 W x 1 into 4 ohms
1000 W x 1 into 2 ohms
500 W x 1 into 4 ohms
Built-in variable low pass-filter
All time low-pass operation
Two independent low level RCA inputs
180-degree variable phase shift
Heavy duty custom power connection
10-gauge speaker connection
Might be ok to run in the garage in 4 ohm stereo on about 20-50 watts. It may run for quite a while that way?
764
123
AbraKaDaBrah
AbraKaDaBrah
North Carolina
Dodge2500HD
    May 31, 2024
    May 24, 2024
