Wiring up T-Rex 10' 2ohm
OllieT
Right guys, this might sound bit daft but I'm trying to figure out how to wire up my sub properly. I got a bd audio T-Rex 10inch 3000w speaker, it's a double coil 2 ohm each. So each coil is 2ohm and I want to run it at 2 ohm so does that matter what side terminal I use or there is a difference? It can run 1000w rms at 2 ohms and this is what I want to push out of it. I can wire it up at 1ohm or 4 ohms but I don't want to. The amp I got is a kenwood monoblock it supports 4 ohm at 500w rms and 2 ohm at 1000w rms. So on a speaker both sides are at 2 ohm so to with side I should wire it up? Or does that matter , can I choose any? Tried to find an answer on google but all I could find is how to wire up in series and other options but nothing about this
This is the subwoofer
Is getting a 1 ohm stable amp out of the question? Sound like that sub can handle more than your current amp can throw at it.
Thing is when purchased sub also brought a new monoblock at same time. Always had a single coil subs and this my first with dvc so I'm new to this type. Think I will wire it up to 4ohm and run at stable 500w rms from amp
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
60
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
465
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
518
573
501
OllieT
OllieT
United Kingdom
OllieT
