What kind of amp do I need 15 inch Sub
Ok cool i did 3000w /16v max output and calculated 187.5amp just wanted to make sure as i said all new but its not so complex.
Just gotta work out battery side now, hopefully not to much price and complexity involved aha but should be good now appreciated.
Do some research on Big 3 electrical upgrade. You'll need some heavy wire for power and ground for the amp as well.
Thanks yes it also suggested on YouTube recommendations so awesome. Will revisit and check through.
Rings? I've had to make them before because the factory speaker mount was plastic, and I've had to make them so the windows would clear the...
159
391
  • Locked
699
Amp
506
Carice222
Carice222
UK
Jeffdachef
