dsp suggestions
psylo535
tampa,fl.
Looking for a dsp to run 2 way active components and subwoofers all while keeping the factory head unit. A few things that would be nice :
small in size
high level inputs
smartphone control ( dont have a laptop but I suppose i could buy a cheap one if needed)
Around $300 or less
An audison big ten is $350 and requires a computer. A pioneer deq-s1000a is $150 and runs through an app. Both have de-eq so I think both will get the job done. I’d personally prefer not to have to buy a laptop
I agree about the laptop. I already have an ipad and have no use for a laptop other than this. I'll take a look at the pioneer, thanks for the reply
DSR1 as well.
610
532
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
psylo535
psylo535
tampa,fl.
psylo535
    May 18, 2024
    May 16, 2024
