Trying to get an amp to see 2 ohms
Buying another amp isn't going to change that your going to be at 4 ohms with those crossovers.
Are you just trying to get power power to the speakers? Just get the DS 440x4.
I understand that, the reason I said about the other amp is that I wouldn't have to worry about being at 4ohms. That amp is 100x4 @ 4 ohms.
79
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
685
Just need to find id to get a users Manuel thanks
nyoc
nyoc
Toledo, OH
    May 31, 2024
    May 24, 2024
