Need Help Deciding On Sub Purchase
Stronger 12 or Weaker 15
  • Skar SDR15 + Skar RP800.1
    Votes: 1 100.0%
  • Skar SVR12 + Skar 1200.1
    Votes: 0 0.0%
  • Total voters
codyc03
28
Utah
Hello! I am looking into getting my first sub and amp setup. I am thinking about getting a 15 inch skar sub with 600W RMS and 1200W max at 1 ohm and an amp with 800W RMS and 1200W max at 1 ohm. I have never had a setup before and don't know how loud this will be or if it will be enough. I mainly listen to rap and don't need anything insane, just want something to get some nice bass and something that will rattle the trunk a little. Would this be a good setup? Any recommendations?
I appreciate all the positive feedback! I've now added another possible combination into the mix. Between the Skar SDR15 with the Skar RP800.1 or a Skar SVR12 and a Skar RP1200.1, any recommendations or insights? Once again, I'm totally new to this so any feedback is great!
Now that you said hatchback, I know it will sound solid. Even a nice 8" sub sounds good in a hatchback, most settle for a 10" with zero complaints. Now, a 15" in said car will drown out your front stage, which you have heard those cars on the road, all boom no voice. In this case I vote on the 12" setup.
They are good at the boom. Hard pounding lowend but lack at the upper notes. If you have a strong midbass setup they will blend fine. Buuut.. for...
13
768
784
codyc03
codyc03
Utah
Firewalker
    May 23, 2024
    May 22, 2024
