This place looks different
jmanpc
CA.com Nostalgist.
Been a while since I been on cacom. Where's the thunderdome? How y'all doing? Is there still a Type R boner? Is goob still around?
To keep it audio related, I am also in the process of doing an all Boss build. I have components, subs and a sub amp. Still need a 4 channel. Yes, you read that right, and yes I am serious.
Sweet, roll with it. Haters will hate. Send that ****. You can probably hit 150's with two 10's with that shitt. Just get enough caps and a good equalizer and you'll be set.
I'm testing to see if you take garbage tier equipment and then install and tune it correctly... Will it sound halfway decent?
I bet I can do it.
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
I have and still do buy quite a bit of audio from there. Great place. Ive never had any issues.. Ever
31
5K
Hi i am planning to upgrade my audio at my rented place, i was using jvc home cinema 5.1 but its extremely bulky, and not so good anymore... i...
When in doubt, use an app called Signal Generator and play tones in the tens. The phase will be easier to distinguish.
jmanpc
CA.com Nostalgist.
jmanpc
Jacksonville, Fl
    May 31, 2024
    May 24, 2024
