Help Me Choose 8s
Yeah, that's my whole larger point about the x-8. It is a more powerful woofer, and it still seems like they tried to aim for it to be like the other x's, but it's still just an 8. 8's are only going to play so low with higher power because of the limitations of the spider sizes and coil diameters. It still doesn't make sense that Sundown themselves recommend a lower tuning for x8 than the sa8, but yet they say don't expect more lows out of it, seemingly. You see what I'm saying? I still think they were aiming to make it a low end monster 8, there's just only so much you can do with an 8"
My current 8's seem to play pretty low, but nobody even talks about them. They did a 148.5 @ 32 hz. Are people wanting 8's to play lower than that? The VFL's didn't even make his list. Those F8l 8's look pretty nice to me.
I tend to agree with you. I would say they are louder woofers over SQ, but I'd rock them for some 8's, personally.
How many subs are you.running and what's your box size and how much power you running?
Well let me put my input in on the 8's. I have had and heard many 8's from jl w7 to dd 1508 to ampere Audio 8, savard hi-q 8, massive audio hippo 8 and even strato 8 which in current running in my vehicle but waiting on my meso 8 that will be here next week. Of my pick I would go with what best fits your budget either used or new but hey I'm just a lover of 8" subs and especially one that sounds good at low and high volumes.
Budget isnt really a issue as 8s don't cost that much and will cost maybe 250 at most. Im looking for the same thing at sounds good at low and high volumes. How do you like the CT sounds Strato 8? what is making you switch to meso 8
I'm currently running 4- VFL 8's on a Sundown SFB3K. The box is 4.1 cubes net after sub and port displacement tuned to 33 hz. It's behind the seat of my Dodge truck. Here's a couple of pics.
I have to agree. Hell I have run the Cadence S2W8's and loved them. The only 8's I didn't like were Massive Audio Hippo. They sounded like complete crap. And they definitely do NOT handle their rated power.
Those SA-8s are probably the best 8 I’ve heard with my own ears in a ported setup. Loud and clean. I also like my DD 8 I ran for years, but the sundown outperformed it by miles when I upgraded, keeping in mind that the DD was an old sub and the sundown is a new beast. I’m not sure if DD is still on the same level as it was 15 years back when I bought it.
This would be a decent amplifier to run on what you have. I would spend a little more and get the 460.4 if you can swing the extra funds. Ive...
Sub should be in the cargo area for best results. I'm skeptical about those unknown brand Chinese head units myself and would stick to known...
I am upgrading standard door & dash speakers in a VW T5 camper (2005) using a plug and play upgrade bundle, continuing with the two-way setup...
169
Icecube91
Icecube91
Vancouver, BC
Icecube91
