Enclosure Help for 2 SA-8s
bgowdy
Heroes are remembered, but legends never die
Well i originally thought about just going with a different sub(s) due to he fact that the 6th order they are in takes up more space in my Caliber hatch then i would like with kiddos sports equipment and what not. I am looking for ideas for enclosure size. I will be going tried and true sub up port back more and likely. I am looking for the best mix of daily and spl that i can get but not competing or nothing just daily banger.
I will have about 1200 or watts on tap depending. I have a 3k but its turned it down due to electrical restraints lol. I was thinking 2.25 cubes net tuned to about 34hz?
Box seems a little big for 8's, but I'm sure it would sound good on that power.
I used BASS Box Pro. It’s what parts express uses on most all their woofer spec recommends. I didn’t build the box phisically that is. I also...
Just remember when you pick a tuning frequency as you go higher the box gains efficiency, but loses low end and tends to become peaky.
Here’s another idea I was thinking of. I’m doing a single 12 in the center of the box just for aesthetics I was wanting ports on the sides of the...
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
bgowdy
bgowdy
Campbellsville, Ky
Buck
    May 31, 2024
