2015 Toyota Prius Build…..
MDGJR
“Fight On!”
2015 Toyota Prius
JL Audio System
Stock Head Unit
Front fill: C3-650 separate components
Rear fill: C3-650 separate components
Sub: 12w3v3 (Custom Ported Box)
Amplifiers: Front fill JD400/4
Rear fill JD400/4
Sub JD1000/1
Signal processor: AudioControl Lc7i
Cool deal. Like how it sounds? You could likely sell the rear components and amp easily, go active up front and invest in a dsp if you ever want to change it up down the road.
2015 Toyota Prius
JL Audio System
Stock Head Unit
Rear fill JD400/4
Sub JD1000/1
View attachment 30314View attachment 30315View attachment 30316
Did everyone else do this too
Only tap 2 speakers and then use jumpers to connect the rest?
Am I the only one who tapped individual speakers to his DSP.
Not less power but less channels. Maybe upgraded all around Bose speakers as well.
I may end up buying the new CDT ES-08 Plus and running customspeakerpods.com 8" speaker pod.
23
Just go by color to color. LF, RF, LR, RR are your speaker wires. Positive + and Negative ( black stripes ). White, Gray, Green, Purple in...
My issue is I already have the box (without the 10" adapter ring) so I'm kinda stuck on a 12, which isn't the worst thing in the world 😂 I had...
15
MDGJR
“Fight On!”
MDGJR
San Diego.
MDGJR
    May 31, 2024
