Wiring a DVC as one ohm.
  • 2
chrisgreenm13
I have a mono amp, with two outputs (one channel), and a dual voice coil 2 ohm subwoofer. (Which I assume means each voice coil is 2 ohms.) I was looking at this wiring diagram to make it act as one ohm, and was wondering if this affected the power I can put to it? I want it to be one ohm so my amp can put more power until I can get a new amp that has two channels and bridge them. Does wiring it like this work? And will it damage anything?
Yes it works. No it won't damage anything as long as you wire it correctly.
Don't buy a 2 channel amp for a subwoofer. Monoblocks are best suited for subwoofers and much easier to find with higher power output.
[/URL]
alright, I’ll save up for a mono that can handle more rms. My sub takes 600 rms, and at one ohm my amp can do 400, which isn’t ideal but should work I suppose. Just won’t sound as good and I’ll make sure not to clip it.
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
518
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
60
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
466
chrisgreenm13
chrisgreenm13
Pennsylvania
chrisgreenm13
just call me KeV
just call me KeV
