Help getting specs for Cadence Shockwave
This has come up before on this Forum I believe like within the last 6 months or so. There should be a Thread to research to maybe get some information. You may be able to contact Cadence and give a serial # if it is still on the back or a # off the board. Crack it open and view the board information, its not under warranty, so taking a little time and removing some screws might serve some justice?
Ill try that thank you.
480
Appreciate the input! I'll check out the calc site and see how it compares. I'm in the beginning stages of building the box. Unfortunately with...
887
Are you turning the volume up higher than before or did you adjust the gain or bass boost?
that kind of describes the sound when the common is lost between a pair of channels. you get some lows and it plays the difference between right...
Panhandle_Jimmy
Panhandle_Jimmy
North Idaho
Panhandle_Jimmy
    May 31, 2024
