64ah headway bank balancer
  • 2
mikeysheff12
So I built a headway bank, all of the polarities are correct. I went off of a YouTube video after doing a ton of research on lithium and headway cells specifically. But I’m trying to connect the balancer, connecting the negative first and then going through the bank, adding the positive on the same bank I already connected my negative onto and going in order. When I tried to connect my first balancer, it ended up frying the balancer when I tried to connect the second bank, now with this new balancer, it’s sparking and I’m afraid it’s going to fry the board like the last one did. I’m not sure what I’m doing wrong or what’s going on
I have this one as well and it has been very useful. Would recommend if you need a versatile battery charger/small power supply.
That’s a 6s balancer but will still work with 4s as long as the last 2 positives are not used.
14.6 is max charge for headway. 3.65 volts per cell. There should not be any voltage drop from your alternator wiring to battery so 14.8 is too high.
mikeysheff12
mikeysheff12
Hartsville, SC
mikeysheff12
