RCA Preouts question/help
Cmberges1
Ok need some easy quick help. I need to know if I should use the Front and Read preouts for bridged front components.
I'm running a JL 400/4 "bridged" to my Hertz Centro components. My Kenwood unit has 3 preouts (4v) so yeah. I have the fronts bridged, right side to channel 1/2 and left to channel 3/4. So should I just use one set of rca (front channel on hu) and split at amp or should I run 2 rca (front/rear) to the amp. That would put the right on a "front" channel and the left on the "rear" channel. Does it matter or is one idea better than the other?
Currently I have the front and sub rcas ran and need to know if I should run another set before I put everything back together.
Thanks y'all!!!!!
Pretty sure on those you can switch it to 2 channel mode and you only need to run rcas to channel 1&2.
Saw this on the RD line, which confused me. Seems like it is implying that inputs 1&3 are for Mono operation. Manual says 1&2, then switch selector to 2 ch.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
882
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
923
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
768
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
860
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
947
Cmberges1
Cmberges1
Commerce GA
