Volume and port area recommendations?
I hope that helps. My box builder was shaking his head. He didn't know what to say after I showed him your interaction with them.
Yeah I feel like it was a mistake and he meant per sub. I decided to go with 13ft3 net, 186in2, 36hz to be a little on the bandwidth side.
38082
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
860
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
82
what ^ said. amp gain setting info, test tones are at the very bottom...
386
Factory. 2021 Chevy Silverado custom trailboss
533
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
Jonnyswboy
CarAudio.com Exclusive
Jonnyswboy
Jonnyswboy
    May 12, 2024
    May 11, 2024
