New Box Build Advice
Grimmjoww
I'm building a box for the HX2 I'm rebuilding. Prime ported enclosure is 1.75cf. Will you guys check my numbers to make sure I'm right please. Will be a slotted L port box.
.75 wood thickness
24"x15"x15" dimensions
Port width 1.5"
Port height 13.5"
Port length 24"
My figures say it should have a net of 1.78cf with 2.37 total, tuned at 33 hz. Trying to figure out material and recommendations are appreciated. Thanks as always.
It's just regular plywood. The stuff that isn't cabinet grade was 60$ last time I bought it. Birch was 90$. Actually, no wood from home depot is really cabinet grade anyway.
Right on, I think I will try play this time. In the past I always built from mdf because it was the "best" but I never thought that. It's cheap and readily available but not very durable. This is going in a Jeep Wrangler that crawls and off-roads a lot. It also gets wet lol, that's why my Fosgate 1000bd no longer works lol.
Just a little wet and nasty that day.
Can anyone tell me if my port area is ok? The calculator says I have 20.25in2 of port area and .60ft3 of port volume.
That’s correct. Could you make a 13.5 x 2 port work? You’re just under 12 sq inches of port area per sq. ft. of box space. 13.5 x 2 port would be close to 16. The rule of thumb is 12-16 sq inches per cubic foot. I’m thinking your port will probably work with that sub, but I always like to get it close to 16 if I have the space.
I can, but I would have to make the box 17" deep and the port 30" long to keep the 33hz tune.
The tricky bit is that they're soft and floppy and they may be stretched a tad to go over the frames. I've used them in the past and come out...
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Thanks everyone for the feedback. I got scared of the 4th being to much for a newbie but did end up building a box to 2.1 Cubic Foot tuned to...
Love this sub, hate AB's site, short on info for sure. American Bass XR-10D2 box recomend: If you want to tune a 2.75 Cu Ft box (for two of these...
Grimmjoww
Grimmjoww
Tennessee
Grimmjoww
    May 31, 2024
    May 24, 2024
