Purchasing a new 4K Mono Block Amp
The replies are priceless on this topic... :LOL::LOL::LOL::LOL::LOL:
Electrical
Stinger 250A High Output Alternator
Big 3 Done
1/0 wiring
Agm d3400 under the hood
Agm d3400 in the trunk
You have the electrical to support a full bridge amp if you want to consider them. Of the 2 you listed, I would go with the D4S amp. But again, I haven't ran either of them nor have I heard either of them and my opinion is based purely on personal preference and amp dyno videos.
Matt
Out of those two I’d get the JP43 simply cause of price and being they are most likely made in the same factory the differences are most likely very minimal.
Electrical
Big 3 Done
1/0 wiring
You have the electrical taken car of. The Sundown or the D4S will do just fine. Take your pick. I've known of the Sundown name for a long time. I've only just recently started hearing of Down4Sound. Maybe it's a good brand that will last for years, I just don't know. But, to do the job, either one will do.
The SALT4 makes 8000W at 1 ohm. How the **** are we feeding that with a """250A""" alternator and 2 AGM batteries?
Well, he specifically said a 4k amp. His electrical is good enough for 4k on music. Just because an amp can do 8k doesn't mean you have to run 8k...
Matt
I want to thank you guys on your feed back in these 2 amps. Still doing more research, anyone have experience running with Soundqubed amps like the Q1-6000
  • Locked
291
I get it. I'd never run a tone through at full tilt to test just how much they can take before it goes all willie nelson either 🤣
72
4K
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
Buy the 4 ch and keep the other. Usually on a 5 ch there isnt much of a substage, but there are a couple with a 1k @1ohm ch., but very few. A 5...
Bigfella1978
Junior Member
Bigfella1978
In the A
    May 16, 2024
    May 16, 2024
