Recone and Impedance
I want to recone dual 4s if I get the recone can use dual 2s
Usually that’s the case. Most audio companies design woofers to be modular between their different VC’s for the same woofer. People will even use different soft parts on a motor they didn’t come with and it can work, if the specifications fit properly. The only way the different resistance VC doesn’t work is if there’s an actual physical issue where the coil won’t work in that motor, and I’m not sure if I know of any woofers like that, at least not now. Typically you can drop any ohm recone into any woofer that is a factory recone.
Hi, i have a b2 hn8p speaker and its blown, i was wondering if anyone has a reconekit or a suggestion for similar conekit so i can fix my speaker.
They all say they are in stock but they aren't. Just like my SSA Zcons and Evils were "in stock" but had a super long build time.
Yeah I had torn one down and used my digital calipers to measure coil size ID & OD and winding height and spiders all had it written down and had...
KicktheSDbasshead
2 builds 2 feet
KicktheSDbasshead
San Diego
Buck
    May 19, 2024
    May 19, 2024
