45 RMS speakers to 80 RMS amp per channel
Here in mauritius, don't think there's midbass. We have pioneer, deaf bonce and hertz midrange. Pioneer being less expensive but harsh at high volume. But why midrange given that full range with high pass frequency will cover all the spectrum from vocal to tweeters?
The speakers are going to be muffled and blocked behind the seats. It would be best to incorporate a midbass or small subwoofer within that cavity to serve any justice in my experiences.
it will be behing the back set head rest and will face towards the front windscreen. dont think the sound will be blocked. note that old sedan cars( some new also) do have speakers in that location. except that for them, the speakers were facing upward but mine will face towards the front windscreen.
Maybe better off with Coax then.
Set the voltage to 20 volts via DMM and it will equal out to around 100 watts. https://www.the12volt.com/ohm/ohms-law-calculators.asp#voltage
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
Drifter mike
Drifter mike
Greece
    May 19, 2024
    May 19, 2024
