What fuse for amps power cable?
Drifter mike
32
Greece
Hello guys,
I bought today a 4 channel TRF M600.4AB amplifier and dont know what fuse to use for power cable. On the internet i have read that because my amp has 2 fuses 40 amps each, i have to use a 80 ampere fuse. But my amps manual says that i need to use a 40 ampere fuse. What is the right ?
Fuses do not protect amplifiers; fuses prevent fires. Fuse size is based on the size of your power wire. Whatever fuse comes with the amp kit is fine.
I bought a second hand fuse board off eBay to pull apart and check. There is a massive AWG 0 or 1 cable that provides the main source. So I don't...
13
185
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
630
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
Drifter mike
Drifter mike
Greece
Drifter mike
    May 19, 2024
    May 19, 2024
