Help
So you have 2 two channel amps that you want to use as a single channel per amp? You also have 2 dual 2 Ohms subwoofers that you want to connect to each amp?
I have the 2 subs connected in series and parallel to each other and need to know the best way to connect them to both amps or should i wire the speaker to amps a different way.
Read the manual it should work okay that way. It says 500 watts but betting closer to 250-300 watts or so the XTR line is a decent line and do what they claim on dyno testing.
161
451
427
Dragonsbld
Dragonsbld
cobden illinois
    May 31, 2024
