Proper way to wire
So I'm curious as to the proper way to wire up an 12v agm battery this is my first time running this much power and it l kind of makes me a little nervous I don't want to blow up burn up anything I'm open to any ideas thanks in advance
Positive to positive and negative to negative. Pretty straightforward. Relax and get it done. You'll be fine.
Someone was telling me I need to have a battery isolator and some kind of DC to DC charger or do I run it directly off the main battery post pos negative the the aux battery post pos neg
I would do as much as you can afford when you place your new speakers in if you cant do it all now. you can always pull your door panels off later...
417
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
523
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
892
Speakmanj1989
Speakmanj1989
Kentucky
Speakmanj1989
    May 12, 2024
    May 11, 2024
