How on earth do I set my xovers?
  • 2
AkisP
Junior Member
I have a Slick A1 4 channel amp and I would like to use the xovers on it rather from the headunit.
How do I go about it? The values are 45Hz min to 300Hz max.
How far do I turn the knob? I wish they were more values written!
I want to cross my HPF @ 100Hz and LPF @ 80Hz.
Thank you
You can get close by using test tones. Like to set the low pass, play a 80 hz tone at low to medium volume and turn the crossover knob till you hear the subwoofer output change.
390
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
777
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
845
AkisP
Junior Member
AkisP
Athens, Greece
AkisP
