ccwatson160
I am using a multimeter to tune my amp to match the sub using a 55hz test tone at 75% max volume. I understand the Ohm's Law calculations for what output reading I need but I'm confused what numbers I should use to calculate with. I have my dual voice coil sub wired in parallel to give me 1Ω but I don't have the number or fully understand how to figure out the impedance for a dual voice coil sub.
My question is using the information below what number should my multimeter read when I adjust the gain for this particular setup. Thank you!
Amp: Pioneer GM-D8701
(1Ω Stable)
Maximum Output
600W (4Ω)
1600W (1Ω)
Nominal Output
800W (1Ω)
500W (2Ω)
300W (4Ω)
Sub: Pioneer TS-D12D2
Maximum Output
2000W
Nominal Output
600W
Nominal Impedance
2Ω DVC
(1Ω Stable)
Maximum Output
600W (4Ω)
1600W (1Ω)
Nominal Output
800W (1Ω)
500W (2Ω)
300W (4Ω)
Maximum Output
2000W
Nominal Output
600W
Nominal Impedance
2Ω DVC
