Dayton 12" HO SVC X2 Build
  • 7
deez283
These will be going in a 2002 GMC Envoy.. Box is 3.0 cuft. Tuned to 30hz with a 12.5" x 3.5" port opening.
Subs will be powered with a Zapco ST-2000XM II or JL RD1500/1 both provide 1500 rms @ 2 ohms.
Progress so far.
Hit a Screw with the router bit when I was doing my cutouts for the subs, had to finish with my $hitty jig saw.. cutouts didn't turn out the best but will grab a new bit for the 2nd baffle.
Progress so far.
Nice! Love the sound of these subs. Clean bass, quick response is how I would describe!
I've ran the 10's in PE's recommended enclosure size and they did pretty good, This time I got more room to work with and it will be a SUV instead of a truck so that alone should help.
Made a little more progress..
I ran the 10’s as well in a single cab.
I still got the 10's in my truck, I don't know if it's cause I upped my power and got a new agm or they broke in, Maybe a combination of both but they are sounding pretty nice now.
I've thought about trying a sealed 15" in my truck but I don't know if I could squeeze the box between my buckets, I got some RSS390HE-22's that call for something like 1.3 cuft.
What truck?
That's coming along nicely. I just found most of a sheet of MDF while doing some organizing in my garage, once the weather cools some I'm going to build something just for the sake of building something.
Same here. I may have half sheet in hand and just in the mood to cut some wood 😁.
A sheet is currently $60 here😩
Thank you, That's how I got going on this box found half a sheet of some nice birch 13 ply and the rest is some 7 ply birch from a shelf I took apart lol.
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
Tuning as low as PE suggests will problematic (long port) unless you go with a passive radiator.
Pay attention to the width to height ratio of the port. The further you deviate from a square shape, the less efficient the port becomes and it...
Some people make to big of a deal about high voltage rcas. I had a pioneer head unit with smart sync ( 31 band eq, crossovers TA etc ). I replaced...
Ive been looking at amarican bass xd 1222 or 1244 ,and sundowns e series, they both seem very good , can't verify sound quality tho but I know...
37
9K
deez283
deez283
Aberdeen, WA
deez283
    May 18, 2024
    May 16, 2024
