Need some help with a amplifier and speaker setup
Bbean12
So I bought a kenwood KAC-M5024BT amplifier for my motorcycle. It puts out 50w x 4 channel rms and has a max power of 600w. I have 4” mounted towers on my bike that I bought with 4” 45KM44 kickers installed that work at 50w rms and 4-ohms. After about a week one of the speakers blew and I’m confused if I wired something wrong or got too powerful of an amp or too weak of speakers or if the kickers were just bad. I’m new to audio so I’d like to ask a community that knows a thing or two. I’d take recommendations if anyone has any. I wired each speaker to a channel. If any more info is needed please ask
9/10 you clipped the signal or tried to play too low of a frequency.
Sounds like you clipped them to failure as stated, and prob expected too much out of them. Can you put a 6.5 speaker it its place with a universal pod?
Judging by everyone’s input I’d assume that is correct. Like I said I adjusted to get some bass out of them and that was probably the wrong move. These speakers need to be played loud to hear anything over my bike. I technically can put 6.5 speakers in there if I bought new towers but I’m also trying to keep it aesthetically pleasing
There isnt a whole lot that can be done without a decent sized fairing to house and accomidate decently sized speakers. A friend of mine has a road glide that he has a pair of Polk 6x9s in the fairing and a pair of 6.5s in the storage bins with an NVX mini 4 ch. The 6.5 Polk Marine Coax may be the way to go?
View attachment 41975So I’m on channel 1-2 where should the knob point? Over the 150-100 or 100-80? Filter LF, off, or HF?
Hpf and somewhere in the 100-150 range. You might can go down to 80hz but again 4inch speakers are not designed to produce bass.
You also so ensure that the signal into the amp is clean and distortion free and that the amp is outputting clean distortion free power.
Setting the gain correctly is the single most important part of setting up an amp
Remove sound system and get a good pair of earbuds or add a BT system.
If earbuds, get wired so they can fit under helmet. Get BT adapter for wired headphones.
If not wearing a fullface, learn to love the potato.
It'll sound 32 billion times better than whatever you put on a bike, AND...you'll gain performance with the lighter weight.
Buy some 6 - ½" midbass speakers and run a pair of them. Run them with a pair of 6-½" coaxials and you should be fine. Run one channel of your four channel amp to each speaker.
I had a bike previously that had a cheap 120$ boss audio system on it and I believe the speakers were only 3”. I have a hard time believing that this system I have here won’t satisfy me if I can get it working correctly. I don’t like headphones while riding. I did that when I started and it wasn’t worth it. I think it’s also worth noting I don’t need the volume all the way up like a street glide to hear around the block. I like listening to music in traffic or cruising around at 35mph with low wind noise. Again my speaker just blew and if I can configure it to not blow I’ll be stoked.
719
You have a lot of great points stated here. I like it.. Nothing wrong with a little head room on any amplifier to run at lower gain settings to...
20
Here is my thought, theory. Those speakers are 80w rms. Half of that is 40w rms. Add the 40 to the 80 and you get 120w. Get an amp that is 120w...
I have 2 Sundown SA10v2 (1000w version) and just replaced my RF R1200 with a T-1500.1bd and OMG! I was considering Ampere Audio, JP23, Sundown...
Check out Crutchfield to determine the iData, PAC, Maestro Harness you will need to retain the infotainment/steering wheel functions, then we can...
Bbean12
Bbean12
New Hampshire
    May 16, 2024
    May 16, 2024
