Kicker car speakers - which model is the best for sound quality? the KS or the CS series?
The only speakers I liked from Kicker were the resolution series way back..
Check out Morel Maximo 6 they can be had for like 159.99 and hard to beat for the money.
Official site the Maximo 6 has been out of stock for awhile. Sonic says “we apologize but this item has been discontinued”. Amazon 3rd party is $299. eBay shows in stock. I don’t see them available like in the past.
526
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
ianik777
ianik777
Mauritius
baldwaldo99
    May 11, 2024
RedRyder18
    May 11, 2024
