need an opinion on this idea.
sounds_explicit
basically i have a 20 tahoe with a lc8i and i have the unit under the seat. im building a bigger system so i want to mount this unit to a amp rack that is more sturdy. the unit will be moved about 4-5 feet back into the 3rd row. but i only ran enough input wire from speaker leads to under the seat. so my q is can i use some sort of separate channel distribution block for my speaker inputs from the block to the lc8i? that way i can use the rest of what wire i have instead of re wiring entire car again? id need 12 spots separate channel, put a terminal ring on the leads going to block terminal lead from block top lc8i. below is what i currently have set on getting. i just need to know if that would be a appropriate option .
https://www.amazon.com/dp/B01AHJV98A/?tag=caraudiocom-20
But since you guys are still here, I have another question. Now that I have a 3k amp, after I get my new battery and HO Alternator, I'll be in the...
272
20K
157
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
116
464
sounds_explicit
sounds_explicit
cleveland ohio
    May 18, 2024
    May 16, 2024
