Help!! Been dealing with this to long
2020civicsi
So in my 2020 civic si I have 2-12 kicker comp R and a decent amp to my knowledge. Every time I press the brake or press the gas pedal the subs like cut out and seem like they want to thump but the amp is going into protect when I press the brake or gas pedal (there electric pedals) but when I press my clutch pedal it’s perfectly fine I don’t get it. Someone pls help.
My rca cable is connected to a line output converter wired to my factory sub
Got it. Was the ground cable set on bare metal? Also check the positive connection points, such as battery terminal, fuse holder, fuse clamps, and terminal screws on the amp. They sometimes loosen with time and cause a energy deficiency. Also make sure the RCA cable is not coiled on top of other wires.
What is your voltage doing when you hard accelerate or brake? The civic have a complex alt control that shuts the alt down to save fuel. Its possible that during those moments the alt is shutting down and the amp goes into low voltage protection.
At the same time like mentioned above I suspect a loose connection somewhere.
I am considering upgrading the sound system in my 2013 Ford F150. I have identified three potential head units: the Sony XAV-9500ES, the Pioneer...
172
515
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
374
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
364
2020civicsi
2020civicsi
Missouri city Texas
    May 16, 2024
    May 16, 2024
