LOC help
  • 2
Tannerman17
17
Indiana
Everything was working fine until I think the positive and ground arc'd on the LOC. The loc still has power and so does my amp..but no sound to sub. The only fuses I have are big one from battery, and whatever is on the amp. The LOC is ds18 2CLC
Damn, so that means the LOC is toast?
I would say so. What brand did you have? Asking because at least they are not expensive.
I never liked the idea of using a loc but I understand it can be easier in these newer cars than changing out the head unit when you have 100’s of options such as steering controls, gps.
Ds18 loc, it was like 90$. And yeah that's why I went the LOC option. Newer car and harder to put in headunit and keep controls.
Yes, use left and right RCA inputs on the amp. Did the LOC turn on? If not, check for a button or switch on it to activate the signal sense...
387
Yeah tapping off the 4 gauge is typically fine. However, you need to fuse the smaller wire right by the 4 gauge at 1 amp (or whatever the small...
877
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
793
Tannerman17
Tannerman17
Indiana
Tannerman17
