Remote turn on wiring questions
  • 2
Sask84gt
Canada
Hey all, new guy here with his first post. Need some help with wiring a remote turn on wire for a Rockford Fosgate p300-10 powered sub.
Little back story to let you know what I’m doing. 1984 foxbody mustang gt. Didn’t want to destroy the factory original dash so decided to install a Kenwood KAC m5024BT amp to run 4 speakers and then added a p300-10 for some extra bass.
Ran the remote wire for the amp to a factory amp pull switch that was in the car stock.
I need to run a remote wire for the sub and am wondering if I can tie into the wire I ran for the BT amp and connect to the same 12v switched source? So basically they both turn on when the switch is pulled.
Thanks
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
598
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Actually, I think I had the adjustment knob turned down while I was setting gain! Rookie mistake
31
4K
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
Sask84gt
Sask84gt
Canada
Sask84gt
    May 31, 2024
    May 24, 2024
