Need help on adding a 3rd Sub
  • 2
MP2121
Hello everyone, I'm new here, and I'm fairly new to wiring/installing systems, although I've had em in my cars over the years quite a bit. Currently, I have (2) JL Audio 12W0v3-4's in a ported box, with a JL Audio JD 500/1 then a JBL Stadium 4, 1500 watt(100x4 rms), to power my factory head unit/DSP, my components up front, 6x9's in rear shelf... I'm wanting to add a 3rd sub(same as other 2), and I'd upgrade my amp to the JL Audio JD 1000/1. If I wired them using jumper wires like my 2 ate presently wired tup, would all 3 subs get 600 watts RMS?? Also my alternator is 130 amps, so would I need a high output alternator as well?? Thanks in advance y'all!
Won't really work. You can wire the subs to 1.33ohms, 12 ohms or 6 ohms. You need a 1 ohm stable amp. Or get some 4 ohm DVC subs which could be wired to 2.66ohms.
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
131
716
758
976
MP2121
MP2121
Missouri
Jimi77
    May 19, 2024
    May 19, 2024
