What caused this?
Clifff150
827
Texas
Recently sold an old sub of mine and a couple days after install, this happened. Any guess as to what caused it? He had it on an Audio Legion 1600.1 and in an aero ported box around 1.3 cubes I believe. It’s a DC Audio Level 4 10.
44124
44125
Looks like the coil jumped the gap and didn't reseat properly judging by the bump in the spider.
Someone was a little overzealous with the power.
Edit: DC recommends 1cf, so an extra 30% of volume would contribute to unloading before reaching the thermal limit, supporting the coil jumping the gap theory.
Oh. So when the box belches. It belches everything out the sub woofer? 🤮
Lol it's a box designed to play a very narrow frequency range with the most efficiency and lowest box rise to maximize the power input. You pretty much only play test tones where the port is doing nearly all the work so mechanical power handling is pretty much maxed out and thermal limits are what stop you. But 30sec tones mean heat build up minimal at normal levels.
It just a competition box that is basically a 1 note wonder. They generally **** to listen to and are bad on the sub for daily use.
The DC lvl 4 subs peak high at tuning regardless of box size and tuning which is why they can rate the box size so low. It won't be musical no matter what you do
so a 🤮box is like a dragster? Built for all out power over a short distance. All out power or blown engine.
Yeah it is single baffle. I have no idea of any real specifics as it’s a guy a family member works with. Thank y’all for all of the input.
Clifff150
Clifff150
Texas
Bobbytwonames
